So, I don't know to use Revit, so let's start there. Conveniently, nobody else really seems to either, so I am being tasked with resolving this:
We are working on a multi-billion dollar project where our company is trying to coordinate everyone and are being forced to use BIM360. A lot of work is happening in Revit, and it's supposed to be collaborative, but none of that actually works, which I think might be tied into what I'm detailing below. So instead, everyone is working on separate models which are then being flattened periodically to 2D and unified in AutoCAD.
Because of varying levels of tolerance for bugs across the dozens of companies involved, we have Revit 2022-2024 (soon likely 2025) models corresponding to the version these companies internally use. In hindsight, we should have tried to force everyone to 2022, but when a project takes more than 2 years, we would have been screwed once licensing stopped working anyway.
ANYHOW ... how do people manage this situation that MUST be relatively common. My understanding is that Revit changes some secret setting in BIM360 that only allows models of that version to come up in collaboration:
How does the Revit file version work with cloud worksharing and Design Collaboration? (autodesk.com)
... meaning we can't have a single project that shows all available models ... instead we have to have (currently) 3 different versions, and we need to keep creating new versions every year until the project completes since you can't upgrade the version of Revit BIM360 will display. And you can't use Connector for a litany of reasons, but the fact it will happily corrupt your project if you try is a big one.
It's unlikely we will be able to force dozens of large companies to adhere to my defined upgrade schedule for their software ... especially Autodesk software. So, how do people do this? This issue came up because someone created a project for R24, but it contains an R22 model that nobody can collaborate on.
