Drawing Log on iPad does not match the website
I have uploaded drawings on BIM 360 Docs. In the website, the drawings are sorted correctly by drawing number. On my iPad, they are not sorting correctly. Please see attached photos for reference. A solution would be greatly appreciated.iPadiPadWebsiteWebsiteiPadiPad
mespaillat
Hello @Anonymous,
Thank you for posting to out forums!
I am sorry to hear about the issue you are having with the BIM 360 mobile app not sorting your drawing log correctly (as shows in the web interface). Do you have other drawing logs or folders that are behaving the same?
Please advise and I will gladly continue assisting you!
Thank you for choosing Autodesk Support!
mespaillat
Autodesk Support Team
I have checked another drawing set and it is doing the same between the two applications. Thanks.
mespaillat
Hello @Anonymous,
I appreciate the prompt response and feedback. I tested this issue on my own internal project using the sample included in Revit. The extracted sheets and views were consistent with each other (web browser and mobile app).
Would it possible for you to PM me a list of the names shown for all items in one of the affected drawing sets so I could try to reproduce the issue in my project as well? Also, would you please confirm the version of the BIM 360 app you are using? The app should be up to version 2.5.0.
I look forward to your feedback and assisting you with this issue.
mespaillat
mespaillat
Hello @ryan.wilsonVKVAB,
I noticed you mentioned that you checked another drawing set and that both web and mobile versions are the same. If you encounter this issue again, please let us know and we will gladly assist.
mespaillat
The issue has not been fixed still. I would like to discuss via phone in order to walk through the issue being had if possible.
