BIM360 - Export of Review table in .csv
phani.bolem
Message 1 of 24
phani.bolem
Hi all,
We have couple of issues in document review workflows
  1. How do we to export all reviews created in the project in .csv file like the way we can export for issues. Can you pls enable the same?
  2. Once the work flow is completed and closed in the final stage, a notification has to go to all the team members part of the work flow as information. Need your help to enable same or provide some option to send notification @ fbim360.jpeginal stage of review.
Replies (23)
Message 2 of 24
Jason_Kai_Jiang
Hi @phani.bolem,
Thanks for the feedback.
For the export feature, could you please clarify the following questions?
  1. Which kind of users will export all reviews? Project administrator or non-admin users?
  2. Which kinds of reviews need to export? For example, all reviews, all opened reviews, all reviews passed the due date, all reviews including rejected documents?
  3. Which information need to export? For example, statistics data on project level (review number, completed review number), or detailed information in each review (comments, markups, review status)?
For notification enhancement, we will evaluate the implementation effort.
Thanks and best regards,
Jason Jiang
Autodesk BIM 360 Document Management team
Jason Jiang
Senior Product Manager
Message 3 of 24
phani.bolem
Hi Jason,
Good morning!!
Here appended my responses in Red.
  1. Which kind of users will export all reviews? Project administrator or non-admin users? I See Project admins using it mainly, However available to across the users will help since if the reviews goes to hundreds it will be easy to filter or provide appropriate filters in the screen. Reports does not cover reviews as of now, that is also needed
  2. Which kinds of reviews need to export? For example, all reviews, all opened reviews, all reviews passed the due date, all reviews including rejected documents?. User will decided based on the need. All reviews should be available by default and export option should work on any filter (open, closed, void, by work flow name)
  3. Which information need to export? For example, statistics data on project level (review number, completed review number), or detailed information in each review (comments, markups, review status)? Every detail captured in BIM 360 data base should be allowed and we should also have an option to create custom attributes in work flows . Auto numbering sequence for each work flow is required to check how many times same wok flow is used and gives proper reference no.
The earliest comeback  will help on this
Phani Kiran Bolem
Message 4 of 24
Jason_Kai_Jiang
Hi @phani.bolem,
Thanks a lot for the detailed explanation. I have communicated those requirement to the development team.
Jason Jiang
Jason Jiang
Message 5 of 24
phani.bolem
@Jason_Kai_Jiang when can we have this executed in BIM360
Message 6 of 24
Jason_Kai_Jiang
Hi @phani.bolem,
The team is still evaluating the different technical solutions. I will update on the thread when the feature is released.
Jason Jiang
Jason Jiang
Message 7 of 24
phani.bolem
Hi Jaison,
DO we have a date from technical team for the above ?
Phani Kiran Bolem
Message 8 of 24
Jason_Kai_Jiang
Hi @phani.bolem,
The development team is still evaluating the different options.
Jason Jiang
Jason Jiang
Message 9 of 24
ChrisGrochowski
Hi @Jason_Kai_Jiang ,
Why is this listed as "solved" when the solution has not been provided?
Message 10 of 24
pieter.vandeweerd
I see this has not yet been implemented in BIM 360. When can we expect this functionality?
Message 11 of 24
neilltupman
I would appreciate an update on this also? My admin. team wanted to export all their 'Reviews' to a CSV file, and couldn't. A Google search lead me here. ADSK shouldn't have this marked as "Solved"; it's not.
@Jason_Kai_Jiang  - what is the update from the development team, since it was referred to them in March 2019? Can you confirm that is being addressed and hasn't been forgotten? Thank you.
Message 12 of 24
Jason_Kai_Jiang
Hi @neilltupman,
So far Docs can only export one Review instance's details into a spreadsheet file.
About export all reviews into csv, please click on the “BIM 360 IdeaStation” link on the BIM 360 community home page.  This will help the Project Manager and developers hear your voice on any changes/concerns with functionality directly for consideration in future builds.
Jason Jiang
Product Owner
Autodesk, Inc.
Jason Jiang
Message 13 of 24
chris_kim
We also need this feature to archive review history.
This is not implemented yet so not really 'resolved'
Message 14 of 24
When will this be implemented ?
Message 15 of 24
hazem.elsirsy
The first post on this request was initiated on Feb. 28, 2019, and till this moment didn't release yet about 13 months is too much regarding this conceptual request.
Message 16 of 24
Message 17 of 24
hazem.elsirsy
This request is essential and no electronic review in the world doesn't has exporting full list, actually, this feature  takes more than too much time to release.
Autodesk BIM 360 has a general problem with managing data, no data filter and export on all columns in most of the BIM 360 modules, which will affect on using of the product directly and gradually push the customers to go to other alternatives.
Message 18 of 24
ChrisGrochowski
I would like all the data to be accessible and not require the use of complicated integrations to get to it. The basic search function needs to be improved as well. It doesn't seem to pick up on any attributes and doesn't seem to look at files in the entire environment. Right now it looks like it only searches the filename and only in the current folder and subfolders. I expect a more robust search feature, think Google, in a web app.
Message 19 of 24
Any news about the implementation? It is still not possible to export all reviews created in the project like the way we can export for issues
Message 20 of 24
v.parnytskyi
