Account Admin > Settings > "Custom Integrations" does not show in BIM360 portal
In BIM360 account, there is no "Custom Integrations" tab.
As long as I know, Contract manager should see this tab.
Could you kindly help me to check?
Product : Autodesk BIM 360 Docs
AG# 110002153857
Mail : [email protected]
patriciakeaney
The accounts that I checked appear to be set up correctly.   When you go to Account Admin> Settings do you see the Custom Integration tab at the top?    That is where you would set up your custom integrations.   If you are not seeing that I recommend that you open a support ticket so an support technician can look at the details of your account.
Best,
Pat Keaney
Patricia Keaney
Director, BIM 360 Enterprise Products
Contact Autodesk Support
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @patriciakeaney provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
