BIM 360 Ops does not support linked models at this time. Binding models into one model is what our clients have been using for workshared models. https://www.autodesk.com/bim-360/facilities-management-software/are-you-delivering-all-the-value-you...
You should start with the ARCH model since Ops used the Revit Room for the locations. Then bind the linked model that the facility technician will want to use for a contextual 3D view. Revit exports the default Revit 3D view {3D} into Ops for the BIm 360 Ops model view.
You can bring in the assets from a scheduled view, which will allow you to bring in Assets on all levels.
Let me know how I can help.
Mark
I am also looking into your salesforce Case 16894325. I hope to have a solution soon.
Mark
Can you try to export the models again, please?
Mark
