BIM 360 Ops Forum
Welcome to Autodesk’s BIM 360 Ops Forums. Share your knowledge, ask questions, and explore popular BIM 360 Ops topics.
Problems with Revit Add In
11 REPLIES 11
Message 1 of 12
4679 Views, 11 Replies
I have Revit 2017.
I downloaded the Add In from BIM 360 Ops website to Revit, and I installed it. But when I open my model on Revit and click on Add Ins, there is no BIM 360 Ops Add In, and I need to export my model.
Can someone help me please?
11 REPLIES 11
Message 2 of 12
Can someone help me please??
Message 3 of 12
katie.murff
The first thing to try is to make sure Revit is closed, uninstall the Add-in and reinstall the Add-in. Then open Revit.
If that doesn't work, it may be fastest if you call the technical support team. Here is a link to the phone numbers: https://knowledge.autodesk.com/support/bim-360-ops/learn-explore/caas/sfdcarticles/sfdcarticles/How-...
Kind regards,
Katie
Katie Murff
Sr Product Manager, BIM 360 Ops
Message 4 of 12
Katie.
Thanks. I have already done that but the problem stills the same. Unfortunately, I am from Brazil, and there is no phone number for my coutry.
Is there another solution I could try!
Kind regards,
Luis
Message 5 of 12
katie.murff
Hi Luis,
What version of Windows are you running? Do you have permissions to write to Autodesk > Revit > Addins > 2017?
Katie
Katie Murff
Message 6 of 12
in reply to: katie.murff
Hi Katie.
I am running on Windows 10.
On a failed try to solve the problem, I installed Revit 2018.
I can not find the file 2018 in Addins file. I am sending images of what I can see on each files.
Thanks.
Regards.
Message 7 of 12
anil_mistry
Hi @Anonymous,
I send you an email via support case that was generated from this post. This could be caused by the dll path in Assembly property not matching with the installation path. Please, review this article for resolving this issue. Let me know if you need additional assistance.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 8 of 12
in reply to: anil_mistry
Hi Anil.
You helped a lot and the problem was solved.
Thanks a lot.
Luis
Message 9 of 12
I need fix that too.
Message 10 of 12
Olá, Luis, como conseguiu resolver seu problema?
Message 11 of 12
uoliveira
Please I am facing the same problem, could you give a hand?
Message 12 of 12
Hi Anil,
could you help me with the installation of Add 360 OPS? I have tried the steps of the article, but without success.
