BIM 360 Ops Forum
Welcome to Autodesk’s BIM 360 Ops Forums. Share your knowledge, ask questions, and explore popular BIM 360 Ops topics.
Few queries on BIM360 OPS
1 REPLY 1
vinay.jirgale
1349 Views, 1 Reply
We had been exploring BIM360 OPS as an Asset Handover and management tool for past few days.
Here are some queries based on exploration for the product,
  1. How and where does the BIM360 OPS fits in BIM-360 ecosystem and Autodesk Construction Cloud vision ?
  2. Is it possible to import linked documents from Revit while importing the data into BIM360 OPS ?
  3. Is Bi-directional transfer of data possible between Revit and BIM360 OPS ?
  4. Is it possible to import the views created in Revit into BIM360 OPS and show the asset locations there ?
  5. Are there any plans to have more reporting and dashboard facilities similar to BIM 360 Field management ?
  6. It seems there are no APIs available for customization of BIM360 OPS ? Is there any plan to introduce them ?
  7. It seems the existing data for the asset is lost when the same asset is imported again from the Revit. Is there any workaround or solution for this ?
Thank you.
BR,
Vinay
1 REPLY 1
@vinay.jirgale  Please see my comment below.
    1. BIM 360 Ops is the Owners Asset Maintenace Management System
    1. BIM 360 Ops does import the URL parameter for links.  BIM 360 Ops does import .jpg and .png images from the MEP Revit Family.
    1. No
    1. By Default, the BIM 360 Ops view is the default Revit 3D View. {3D}.  However, you can use the publish option for layered views, if your assets, rooms, and 3d views are configured correctly and published correctly.
    1. Currently, there are over 21,000 live reports and graphs in BIM 360 Ops.
    1. BIM 360 Ops does not have Open API's.
    1. Assets Data should only be overwritten if it has changed in the model.   The model should be prepared according to these guidelines.
    2. https://www.autodesk.com/bim-360/facilities-management-software/are-you-delivering-all-the-value-you...
Mark Mergenschroer
Autodesk Tandem
