BIM 360 Ops Forum
Welcome to Autodesk’s BIM 360 Ops Forums. Share your knowledge, ask questions, and explore popular BIM 360 Ops topics.
Can't install the Revit add-in
5 REPLIES 5
Chad-Smith
2421 Views, 5 Replies
I'm having an issue with installing the Revit add-in.
5 REPLIES 5
yurikim
in reply to: Chad-Smith
Thank you for your posting. Have you tried to download the installer again? Also have you logged in as Admin?
Also refer to this:
https://blogs.msdn.microsoft.com/vsnetsetup/2012/03/14/msi-installation-fails-while-installing-a-cus...
Yuri Kim
Product Support Specialist, AEC
Chad-Smith
in reply to: yurikim
Thanks Yuri.
That link you provided to the MSDN worked.
I had a lot of trouble understanding exactly what it was referring to towards the end of the steps, but after much persistence I finally worked it out.
I am facing the same problem, could you help me with the installation, please?
hi
https://akronhomepros.work/
HI @anastasiyabert67 ,
To resolve this BIM 360 Ops add-in installation issue, do the following::
  1.     Create a new Windows local administrator account.
  2.    Create a local user or administrator account in Windows.
  3.   Install Autodesk BIM 360 Ops Add-in for Revit from the new admin account.
From experience, this happens because the Add-in is being installed as an admin user and the user profile is not an admin; this creates an installer folder that is Read-only user profile, with no install access.
Let us know how we can help.
Mark Mergenschroer
Autodesk Tandem
