Selecting Issues in Bulk from File
It would be helpful to be able to select multiple issues at once from a certain location within one file.
Right now, you can only bulk select issues to review or edit them from the "List" section of a certain location (or you can set report parameters to review issues, but mostly this is too time-consuming for the particular task). Often I would like to look at the "Pins" on a drawing, and select all of the pins isolated to a certain part of the plan, facade, etc. and edit only those. Right now, the only way to do this is to select each pin one-by-one to edit, or manually jot down the issue number associated with the pin. A better way would be to have a "click and drag" type option to select multiple pins.
1 Comment
dagamarosem
 It would be very useful to bulk edit issues in Field Management. The main area that this would be beneficial for changing the company assigned to issues, issue locations, or even modifying the issue type.
