Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
In BIM360 rotate a sheet published by Revit
For better reading please make it possible to rotate a sheet published by Revit In BIM360.
(Note: It is possible to rotate a pdf which is created of the same sheet)
Thank you
