Show only
Search instead for
I agree that the BCF files are missed to export or import to BIM360Glue.
The same question i asked to Autodesk and received the following feedback.
Navisworks natively doesn't support the BCF file format. Therefore a connecting workflow to Glue for this format isn't in product scope today. You are referencing the BCF manager - this is a product from another company, KUBUS BV, which was made available in the Autodesk App store. If you want to enhance Glue, being able to import/export BCF files, please support this existing request https://forums.autodesk.com/t5/bim-360-ideas/bcf-import-export-in-bim360-glue/idi-p/6671238.
So this post is even older than the other one inside the non-Glue category, has more votes and is not even 'under consideration' (whatever that is supposed to mean). BCF has been around considerably longer than BIM 360, it is well documented and should be available out of the (virtual) box. After all Autodesk has decided to allow exports to pdf and xls which are two other non-Autodesk controlled formats.
