Is there a way of viewing the shared parameters in BIM 360 glue when we have created these in the Revit model. I have tried gluing the model through the BIM 360 plug in and then exporting the file as a NWC and gluing it that way?
Thank you for your posting @Anonymous.
Could you elaborate more on what you are trying to achieve? If you have used Project parameters using shared parameters, this parameter will be still available in Glue.
Cheers,
hi i can't get this to work in glue when i export and upload nwd none of my custom parameters appear in glue but appear in navis , can you advise please?
checked all the drop downs and it doesnt pull through
many thanks
