BIM 360 Glue File Explorer View?
Were you ever able to do this? I need to copy files from another folder, into bim360 glue, and it's tedious from the web, or with the desktop app (that looks just like the web).
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for participating in our community! Since you replied on one of the old post I have moved your question to a new thread.  At this time this is not an available option in BIM 360 Glue, you can upload and download multiple files from the Desktop application with a minimum of clicks. Log into BIM 360 Glue and then go to the Models module. Click the List view and from here you can select any number of models and download them (see attached).
If you have any feedback that you would like to submit regarding any enhancement, please click on the “BIM 360 IdeaStation” link on the BIM 360 community home page.  This will help the Project Manager and developers hear your voice on any changes/concerns with functionality directly for consideration in future builds.
Please Let me know if this helps.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
