BIM 360 Glue Forum
Welcome to Autodesk’s BIM 360 Glue Forums. Share your knowledge, ask questions, and explore popular BIM 360 Glue topics.
BIM 360 Glue Add-in For AutoCAD does not display model TEXT
11 REPLIES 11
Message 1 of 12
knoelte
2324 Views, 11 Replies
Why doesn't TEXT display when i attach a model to autocad using the BIM 360 Glue Add-in? or when I attach a Coordination Model (.NWD) that lives on my desktop.
The TEXT DOES DISPLAY when i use the BIM 360 Glue desktop app and the Add-in for Navisworks... TEXT DOESN'T DISPLAY when i use the Add-in for AutoCAD.
2D lines appear in AutoCAD within the 3D Coordination model (.nwd) just not text...
This is a problem because we NEED to see text to coordinate our files using the GLUE tools!
11 REPLIES 11
Message 2 of 12
anil_mistry
in reply to: knoelte
Hi @knoelte,
Thank you for participating in our community! Are you opening this model from BIM 360 Glue project into AutoCAD and you are not seeing text there? Would you be able to share screen capture of this behavior?
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 3 of 12
knoelte
Coordination Models do not display text?!
Coordination Models (nwc or nwd) DISPLAY TEXT for all listed products (below) EXCEPT WITH AutoCAD:
  • BIM 360 Glue desktop App (TEXT SHOWN)
  • BIM 360 Glue Add-in for Navisworks (TEXT SHOWN)
  • Revit Insert Coordination Model (TEXT SHOWN)
  • BIM 360 Glue Add-in for AutoCAD (TEXT NOT DISPLAYED!)
Text is required for Coordination (communication). Having a 3D model without the ability to see text is 1/2 effective for coordination.
Message 4 of 12
knoelte
in reply to: anil_mistry
See attached photos/ navis model - 1 of 2
Message 5 of 12
knoelte
See attached photos/ navis model - 2 of 2
Message 6 of 12
anil_mistry
Hi @knoelte,
Thank you for sharing this model with me. Would you be able to share DWG file with me so I can try duplicating this behavior on my end.
Anil Mistry
Message 7 of 12
knoelte
no problem.
The fabrication object enabler will need to be installed to see our piping (based on your AutoCAD year). this may not be required for if you are just troubleshooting the TEXT.
CADmep 2014 Object Enabler
CADmep 2015 Object Enabler
CADmep 2016 Object Enabler
CADmep 2017.1 Object Enabler
CADmep 2017.2 Object Enabler
CADmep 2018 & 2019 Object Enablers
Message 8 of 12
anil_mistry
Hi @knoelte,
Thank you for sharing this file with me. I will try to duplicate this behavior on my end and will give  you an update soon.
Anil Mistry
Message 9 of 12
anil_mistry
Hi @knoelte,
I just want to let you know that I was able to duplicate this behavior on my end and have reported this to development team for further investigation and will give you an update soon.
Anil Mistry
Message 10 of 12
knoelte
Thank you Anil
Message 11 of 12
anil_mistry
Hi @knoelte,
I just want to let you know that development team is still investigating this behavior. I will keep you posted.
Anil Mistry
Message 12 of 12
Was there a fix for this issue? currently having a similar problem with opening a .NWD file in the BIM 360 Glue ipad app and not having TEXT display
