I am using Autodesk BIM 360 Glue for desktop. Whenever I try to use Mark-Ups, or Measurments, or Clash I get a message that says "Can Not Create Module"
Why is this happening?
Solved by frederick.regala. Go to Solution.
I have not seen this error before, it looks like it is having problems loading the features you are selecting, it could be an installation issue, could you perhaps try uninstalling Glue Desktop and re-install?
Dave
Hi -
To add to Dave's suggestion, please try the following steps to uninstall and re-install Glue Desktop:
Restarting the computer is not necessary but I recommend it.
I hope this helps.
Frederick
Welcome Scott. First thing I notice is that your models list is not showing despite the Toolbar indicating it should be. Please try this to fix both issues.
Go up to your profile drop down and select Options. On the options screen press the "Restore BIM 360 Toolbar Defaults" button. The screen should flash and your models listing should appear. Position/Dock it back as desired and then try opening one of the other tools that was throwing that error message.
Let us know if this fixes the issue for you.
Hello Frederick,
Your solution worked for me two times.
After I followed your steps, my modules came back.
THanks,
Moses
I have the same error, but there is no Options in my drop down list. And there is an error where trying to uninstall via Program and fesatures. Any other suggestion ?
