I have created some reports (formatted as *.rtf) out of the BIM Field Web.
Everything runs well with the export but when I try to open the files within Word the program is crashing down.
Every repairing did not solve the problem. I have tried with different reports as well as different Word versions (2003 – 2010).
I have found some indications that it could be based on a not compatible text box with short line breaks. But this is just a rough guess.
Can someone reconstruct that filer?
Or better is someone can help me to solve?
Marc
Hello Marc,
In regards to the reported behavior of RTF reports generated from BIM 360 Field causing Microsoft Word to crash, I have escalated this issue into a support case. A member of BIM 360 support will reach out to you directly to begin troubleshooting.
Don
Product Support Specialist
I solved the problem with a workaround.
Typical about these reports is that they are completely made of \shape elements.
They have 0 margins and text outside the shapes.
When I added one line break (\par) at the beginning of the first page before the first shape the problem was gone. I did that by editing the rtf with a plain text editor.
Cheers,
Marc
