We are not able to print and send the reports as PDF from BIM 360 Field anymore. Is this a system update?
Solved by patrick.beattie. Go to Solution.
Hi Lisa,
Thank you for posting to the BIM 360 Field forums. I'm sorry that you are running into this issue.
I believe you are referring to the Print Daily Update no longer shown within the Daily Updates area. This behavior has been reported to the product team and they are looking into getting this resolved.
For the time being you can run a Daily Update report from within the Reports section of BIM 360 Field. From the Reports section you can select which day and author you want to run a report for.
We are actively looking into getting this issue resolved as soon as possible. Once resolved, an update will be posted on this forum.
Please let us know if you have any other questions.
Best regards,
Patrick B.
Global Product Support
On one of our site, the subs are doing Daily Updates, when they look at the REports section to do as recommanded, they are not able to do so, they only have access to Issues and Tasks. So any idea of whe the fix will be done ?
André
EBC inc.
The Print Daily Update button is back within BIM 360 Field. Thank you for bringing this to our attention.
Let us know if you have any additional questions or comments.
Best regards,
Patrick B.
