Wondering why I can log in to Field on my PC, but have never been able to log in on my IPad? I get to the sign in screen, input my username or email, press "next", and it flashes "verifying" for 1/2 a second and just goes back to "next". I can log in on anybody else's IPad. I even went so far as to get a new IPad Pro, thinking mine was out of date or something, still does the same thing. Getting frustrated.
Hello @Anonymous,
Thank you for your post. I am sorry to hear that you are experiencing troubles with your iPad application for BIM 360 Field.
May I please ask you if you have tried to uninstall and reinstall the application?
Also, on your iPad, if you go to Settings > BIM 360 Field > Service URL, could you please let me know if you have both of the following links: https://bim360field.autodesk.com and https://bim360field.eu.autodesk.com ? (the line should appear as: https://bim360field.autodesk.com,https://bim360field.eu.autodesk.com).
Another question would be if the app is up to date.
Thank you for answering to my questions! I look forward to hearing back from you soon.
Best regards,
Hello @Anonymous,
Thank you for your reply.
Could you please share with us your iPad hardware specifications?
Also, would it be possible for you to send us the diagnostics from your iPad? To learn more about how to send diagnostics, please find the article bellow:
Thank you. I look forward to hearing back from you soon.
Best regards,
@Anonymous
Thank you very much for your reply. I was my pleasure to try to assist you with this issue?
Would you please share with us what the problem was, so that we can then check your post as a solution so that it will help other community members that might encounter the same behavior?
Thank you very much!
Best regards,
