Failed to Authenticate
Big 360 App for IPad Air2 is failing to authenticate. Please advise
jlovin
Community Visitor
Community Visitor
We are having the same exact issue. We have a valid Autodesk Login and currently can log into the BIM 360 website with no issues from a PC.
I am having the exact same issue.  Has this problem been resolved?
jlovin
Community Visitor
Community Visitor
Yes; Autodesk had to make a new BIM360 admin account for our company. Once
you have access to the BIM360 account through your desktop web browser you
will need to add BIM360 Field access to a new project. Once added the IPAD
will login to BIM360 Field.
All the Best,
[image: ingleedbdc1]
*HVAC - Plumbing - Fire Protection*
*Engineering & Commissioning Services *
*John N. Lovin, CxA, LEED AP BD+C | Principal *
550 11th. Street, PO Box 1586, Augusta, Georgia 30903
Ph: (706) 774-1020 *203 | Fax: (706) 774-0065 | Mbl: (706) 830-6540
[image: link]
NOTICE: This E-mail (including attachments) is covered by the Electronic
Communications Privacy Act, 18 U.S.C. §§ 2510 -2521, is confidential and
may be legally privileged. If you are not the intended recipient, you are
hereby notified that any retention, dissemination, distribution, or copying
of this communication is strictly prohibited.
Please reply to the sender that you have received the message in error,
then delete it. Thank you!
Chad-Smith
I'm currently experiencing the same issue today.
I have access to the project through the Field web browser UI, but can't authenticate through the iPad.
Luciane_Conceicao
Autodesk Support
Autodesk Support
Please have a look at this document:
"Can't sign in" error when logging into BIM 360 Field on the iPad
Hope this helps.
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
Autodesk, Inc.
Luciane Conceição Taylor
Autodesk, Inc.
Please click the button "Accept Solution" if this suggestion resolves your issue.
I've tried several different steps of this process shown and still have no access through iPad.
