Hi all,
I have a project team unable to create Daily Updates on the iPad - the loading circle appears, cycles and then disappears without enabling the DU. They can create the DU on the desktop application so it isn't a permission issue. I have checked and can create DU for the project (for the same project) on my iPad so I am confused - any ideas?
Col
Hello @colin.bell,
Hope I can give you some pointers, you might have looked at those already but just in case.
Access:
1. In your project admin permission tab you have 3 locations (older Subcontractor Role) to verify for access.
the second variable is not available anymore as seperate setting in the new Subcontractor Role. See specific Subcontractor Role for those settings.
Version:
1. Are you using latest version on iPad (version 4.19) right now.
Data:
1. Open your iPad en delete your local cache data in your iPad.
Support:
1. if it is still not working I would contact your reseller or Autodesk support.
Hope this helps you out.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Niels Oomen
Cadac Group BV
Sr Consultant AEC
