BIM 360 Field Forum
Welcome to Autodesk’s BIM 360 Field Forums. Share your knowledge, ask questions, and explore popular BIM 360 Field topics.
Customize view for checklists under equipment
6 REPLIES 6
743 Views, 6 Replies
Is there a way to customize checklists fields under equipment?  Most importantly status?
6 REPLIES 6
don_simpson
Hello jdentino,
Thank you for contacting Autodesk.
It is possible to customize custom properties within BIM 360 Field, including for both checklists and equipment records. See the Help article To Add or Edit Custom Properties for additional reference. For additional reference, please also see To Work with Checklists.
While it is not possible to add new checklist status values, you may edit the statuses of the equipment record to which it is associated. Please see the Help article To Work with Equipment Records.
Please let me know if you have any additional questions at this time.
Don
Don Simpson
Technical Support
anil_mistry
in reply to: don_simpson
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @don_simpson provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
in reply to: anil_mistry
No, this did not help.  I would like to customize the checklists fields under Equipment.  See attached screen shot. I would like to add status (open/closed) in this view.
don_simpson
Hello jdentino,
The provided screenshot appears to show an arrow to the "#Open" heading. Are you looking to add other properties within the checklist tab of equipment after this value? If so, this is not possible.
If you were looking to add additional custom properties for those checklist templates linked to equipment records, that would be done by using the instructions in the previously provided link. Those custom properties would be visible within the checklist or possibly the checklist grid within project.
Don
Don Simpson
Technical Support
anil_mistry
Hi @Anonymous,
Anil Mistry
"The provided screenshot appears to show an arrow to the "#Open" heading. Are you looking to add other properties within the checklist tab of equipment after this value? If so, this is not possible."
This would be a feature that would save me and my team a ton of work compared to having to open each and every checklist to verify whether or not the checklist was closed. You'd think that this would have happened sometime over the last six years.
