Can anyone assist with how to use the free version of Bim 360 Docs.
When trying to log in, I am directed to a screen to request an invite.
Is bim 360 docs linked to other software?
Is it not a standalone app?
Solved by johnharvey. Go to Solution.
Solved by benjamin.peake1. Go to Solution.
Hello John,
It sounds to me like you might not have set yourself up a Docs account yet, to set yourself up with an account please follow the link below.
Autodesk BIM 360 Docs - Get BIM 360 Docs (Free Forever)
Once you have inserted the email address which is linked to your Autodesk Account on this page and clicked 'Get Started Now' you should automatically be taken to your new Free BIM 360 Docs account where you will be able to start using the software straight away.
Following this first time any subsequent times that you want to login to BIM 360 Docs you should do this by following the sign in link below and using your Autodesk Account login details.
I hope this answers your question. Let me know if you need any more help with this issue. If this has answered your question please select this answer as an Accepted Solution using the 'Accept as Solution' button.
Best Regards
Benjamin Peake
Product Support Specialist
Autodesk, Inc.
Hi John,
I am very glad to hear that this has helped you.
Please let me know if you need any further help with your new Docs account.
Benjamin Peake
Autodesk, Inc.
Hi Benjamin!
I try to figure out is there a Free Forever version of BIM 360 Docs as it is claimed on the page you have provided a link to? Or it is a trial version?
Kind regards,
Evgeny
Hi there,
it says "(Free 30-day Trial)". Plus, if you read the terms of use (I know, hardly no one ever reads that), it also says under section 12 "Your use will be limited to non-commercial evaluation purposes [..]".
No, no free forever and not for commercial projects, it's really a trial only.
Cheers,
Ingo
Hi ..
Is it BIM 360 Doc still can get free version for one project?
@Anonymous wrote:
Hi there,
Cheers,
Ingo
@Anonymous wrote:
Hi there,
Cheers,
Ingo
Please read the quote under your question. This answers all. There is no free version.
@thuzarmyatmonSGA3W wrote:
Hi ..
@Anonymous wrote:
Hi there,
Cheers,
Ingo
