Uploading to "Plans" folder is made as a very automated process. Wonder if in the cases when the file contains more than one sheet there will be pop-up giving the ability to select naming pattern for them and ability to select only the sheets that should be uploaded. Ideally, there should be some settings tab for pre-defining upload process, i.e. full-auto as it is now or not to upload sheets that contain certain "mask" in sheet name, define this naming sequence, i.e. name of source file with added sequential sheet number, etc.
Also, need an ability to correct the name of the file during upload and when it already sits in the "Plans" folder.
Also to drop empty "Layout" files during upload can be one of the options in those settings.
An automated process should be able to recognize the issue of same name during the upload and not to do multiple overwrites with next sequential version number.
Solved by ilai_rotbaein. Go to Solution.
Any chance that would include a 'reprocess' option. Sometimes get a 'finding viewables' process error on upload. Given (I assume) all the bits are there already would be nice to tell 360 to regenerate the view without repeat uploading.
