I have 3-page PDF file and I tried to upload it to "Plans" and to "Project Files"
To "Plans" it went almost well except for the time when I was suggested to publish but there was no possibility to amend title and drawing number, just rectangular frames with exclamation mark near each of three plan and title block combo. Maybe it was still uploading or processing something. After few minutes and few page reloads I was able to see fields for titles and numbers, I then was able to publish and got 3 new files as needed.
To "Project Files" it did not go as I thought as I was reading that pdf uploaded to "Project Files" are not split. It only half way truth as what I got is one document title but once I opened it there are three separate sheets. So I cannot just scroll down to read next page, mouse roller is zoom in-zoom out function. To go to next sheet I have to click left pane with sheets and version icons then select next title of next sheet and then only it goes to next page.
Pgdn/Pgup buttons are also work as zoom in/out buttons. Tiles pane is taking approximately 1/5 of the screen.
Preference for "Project Files"PDFs is to have them in normal reading mode so scroll down will move slowly via all pages and Pgdn will switch to next page, Ctrl+mouse roller will zoom in/out. Similar to Acrobat Reader functionality.
Solved by ilai_rotbaein. Go to Solution.
Is there still no solution for publishing multiple page PDF to plans without breaking them up to single sheets? There are disciplines in different projects that makes listed detail sheets, that spans over multiple pages. another example is the schedule for sheets, that often extends over 2-3 pages. I would prefer that these would combine in one file under one drawing number/name. These are sheets that we would like to have in plans, not project files.
