BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
BIM 360 Design Bandwith + Technical Spec Requirements/Recommendations
6 REPLIES 6
Lichu.Chen
2947 Views, 6 Replies
I would like to know the official technical spec requirements for a team to use BIM 360 Design.
IT will need to know minimum and recommended bandwith/internet speed, etc...for using all the BIM 360 products.
6 REPLIES 6
KyleB_Autodesk
in reply to: Lichu.Chen
5Mbps symmetrical to the open internet. For each user, with a utilization factor of 0.3 once you get over ~15 concurrent users.
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
Hi @Lichu.Chen,
I'm just checking in to see if you need more help with this. Did the suggestion that @KyleB_Autodesk provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
sburke
in reply to: KyleB_Autodesk
is there a reason why none of this is in the help files it would solve a lot of issue?
Hello Kyle!
Today a client called asking this same question. The answer we gave was "A solid 100mbps for upload and for download is a good minimum" .... do you agree that this is a good answer? I mean for a firm of a small-medium size.
@Basam.Yousif wrote:
Hello Kyle!
It all depends on the number of subscribers that would be concurrently using Revit Cloud Worksharing.  If there was ~15 such users, then yes, it would be a good recommendation.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Thank you!
I wish you could expand on this information (Per license, for a firm up to 50 concurrent users, 100, 500, etc. and maybe even include what type of BIM360 service or "module" if one uses more than the other e.g. Glue vs. Design) and publish it onto a "Sys Req's for BIM360" .
Thanks again!
B
