BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
Takes too long for the doc management service to activate in a new BIM 360 project via Forge API
23 REPLIES 23
Message 1 of 24
xavier.loayza
2832 Views, 23 Replies
The doc management service takes too long to activate. We are experiencing this issue since last Friday.
Projects get created without problem, and users get added to projects(even-though they do not get an invitation email until doc management services are active). However, the doc management services keep spinning between 1 to 4 hours  so, we do not have access to project folders. I found others having the same issue in Stackoverflow.
https://stackoverflow.com/questions/59570209/is-it-possible-to-load-new-cloud-bim-360-links-in-a-rev...
https://stackoverflow.com/questions/63691307/the-document-management-is-not-active-from-forge-api
23 REPLIES 23
Message 21 of 24
zhong_wu
in reply to: adt
There was an issue related to user token, and this was fixed around early this week, did you still see this issue now?
John Wu
Developer Technical Services
Autodesk Developer Network
Message 22 of 24
zhong_wu
in reply to: adt
Hi, there was an issue related to user's token, not sure if this is caused by that regression, but this was fixed early this week, did you still see the issue now?
John Wu
Message 23 of 24
adt
in reply to: zhong_wu
It was pretty slow yesterday morning and the day before, but did eventually resolve itself later in the day.  We will continue to monitor.  I did see on the health website yesterday that there was downgraded services so it could have been tied to that.  Thanks for the quick reply!
Message 24 of 24
mcorredor
in reply to: xavier.loayza
We are also having some issues with this. "Activating..." and the loading wheel have been loading for a long time for Document Management, Project Management, Design Collaboration, and Model Coordination.
Autodesk DevCon in Munich May 28-29th
