server error 500 on field API end points.
mnelson-disney
Message 1 of 9
mnelson-disney
https://bim360field.autodesk.com/api/get_issues
Is throwing an exception when using a valid issue_filter_id URL parameter.
Please advise. This is impacting multiple developers on our side. ( in and outside of our network)
Replies (8)
Message 2 of 9
mikako_harada
Hi Matthew,
I can reproduce the error.  I will log a change request.
In a mean time, you may workaround by using /fieldapi/issues/v1/search  with conditions parameter.
This may help how to use conditions parameter:
https://fieldofviewblog.wordpress.com/2015/07/16/field-api-filter-issues-by-issue-type/
Note:  I see filter_id option with issues/search. But does not look like it's functioning, either 😞
Mikako Harada
Developer Technical Services
Message 3 of 9
Hi Mikako,
This is a disaster, services that we depend on for important integration work  that have been running for the last 4 years have now failed because of the bug.
Can you very urgently provide an ETA when this bug will be fixed!!!
Peter
Message 4 of 9
mikako_harada
Hi Peter,
Thank you for confirming that it was working before.  (I was wondering about that myself as I thought it was working last time ...)
I notified the product team.  I will update you when I get new information.
Sorry for the inconvenience.
Mikako Harada
Message 5 of 9
mnelson-disney
Are there any updates on this issue?
Matthew
Message 6 of 9
Hi Matthew,
FYI, I re-wrote my application using "/fieldapi/issues/v1/search" to get around this bug.
Message 7 of 9
mikako_harada
Hi Matthew,
The engineering team is investigating as a priority issue.  The product manager is aware of the issue, too.   We will update you when we have more info.
Mikako Harada
Message 8 of 9
Interestingly, at the time of this post /api/get_issues is working if I send a parameter "filter_id" instead of "issue_filter_id" (i.e., keep the same code just rename "issue_filter_id" to "filter_id") .. however still fails with a 500 error if I submit the usual "issue_filter_id" parameter as specified in the API docs.
Hahaha, obviously not going to rely on this workaround long-term since this is not API-doc-consistent behavior, but still interesting.
Message 9 of 9
mnelson-disney
Thanks for escalating.  Any updates yet?
