Script to automate the publishing of views from Model Coordination to Autodesk Docs in ACC/BIM360 using the Autodesk API?
danii52053
Message 1 of 1
danii52053
I am trying to write a script that automate the process of publishing views created in Model Coordination to Autodesk Docs using the Autodesk API, but I am unable to find any relevant endpoints or methods in the API documentation.
Here is an image showing the feature I'm referring to:
(https://i.sstatic.net/lGLnFT89.png
I've looked through the following Autodesk API documentation:
I need guidance on whether there is an API endpoint or method available to:
  1. Automatically select and publish views from Model Coordination.
  2. Push these views to Autodesk Docs without manual intervention.
Has anyone had success automating this process through the API? If so, could you provide some insight into how it was achieved or whether a custom integration is necessary?
Replies (0)
