POST /api/checklists - Detailed Guidance
I'm trying to upload a new checklist via the API for 360 Field. I have a template checklist setup in a project, see below:
        "template_id": "2347c055-66a7-4119-b831-d3f222a92e95",
        "name": "API Checklist Type 2",
        "description": null,
        "tags": null,
        "auto_create_issue": false,
        "company_id": null,
        "priority": null,
        "updated_at": "2019-02-12 12:46:29 +0000",
        "checklist_type": "QA/QC",
        "header": "",
        "footer": "",
        "issue_type_id": "d713cd28-8b3f-4468-811e-4c6494f14273",
        "custom_field_values": [],
        "template_items": [
                "template_item_id": "990d1376-4892-45a3-ae14-bd0c8bdffa67",
                "number": "",
                "position": 1,
                "item_text": "Automatically Populated?",
                "more_info": "",
                "is_section": false,
                "company_id": null,
                "response_type_id": "24e6efab-0f52-446f-9cc5-db49caaa1ce3",
                "default_answer": "",
                "spec_ref": "",
                "attachments": [],
                "document_references": [],
                "document_folder_references": [],
                "uri_references": [],
                "root_cause_id": null,
                "issue_description": "",
                "response_type": {
                    "display_type": "drop-down",
                    "name": "True, False, N/A",
                    "required": false,
                    "position": 782,
                    "possible_values": [
                        "True",
                        "False",
                        "N/A"
I'm using the POST /api/checklists endpoint to try and upload a new checklist. I'm sending the following data as a string in a checklists parameter:
      "tags":"",
      "template_id":"2347c055-66a7-4119-b831-d3f222a92e95",
      "status":"Open",
      "identifier":null,
      "name":"API Checklist - Febru",
      "checklist_type":"QA/QC",
      "description":"",
      "area_id":null,
      "source_id":null,
      "source_type":null,
      "company_id":null,
      "checklist_items":[
            "template_item_id":"990d1376-4892-45a3-ae14-bd0c8bdffa67",
            "comment":"",
            "position":1,
            "spec_ref":"",
            "response":"True",
            "location_detail":null,
            "company_id":null,
            "area_id":null
When I run this I get a code 500 server error and nothing other meaningful error message. If I check the Field 360 website I note that a checklist has been created; of sorts - it only includes the header data, no other fields are included:
What needs to be sent to ensure that fields are populated when creating a checklist using the API?
If I reduce the fields to a bare minimum, I still get the same result, a 500 error.
ANY help would be greatly appreciated!
eason.kangEDLV4
Autodesk Support
Autodesk Support
I'm checking with our engineering team, and will get you back A.S.A.P.
Cheers,
Eason Kang
Developer Advocate
Developer Advocacy & Support Service
Autodesk Platform Service (formerly Forge)
eason.kangEDLV4
Autodesk Support
Autodesk Support
Apologizing for the delay, it takes me some time to discuss this with our engineering team. To create a checklist via API, you have to pass all fields below and the response_type_id as well as the id attribute.
curl -X POST \
  https://bim360field.autodesk.com/api/checklists \
  -H 'Content-Type: application/json' \
  -H 'cache-control: no-cache' \
  -d '{
  "project_id": "{PROJ_ID}",
  "ticket": "{YOUR_FIELD_TICKET}",
  "application_version": "4.0",
  "checklists": "[{\"id\":\"{RANDOM_GUID}\",\"template_id\":\"2347c055-66a7-4119-b831-d3f222a92e95\",\"identifier\":\"\",\"name\":\"API Checklist - Febru\",\"responsible_company_id\":\"\",\"status\":\"Open\",\"checklist_type\":\"QA/QC\",\"priority\":\"Medium\",\"tags\":\"\",\"project_id\":\"{PROJ_ID}\",\"created_by\":\"{USER_EMAIL}\",\"created_at\":\"\",\"updated_at\":\"\",\"description\":\"\",\"deleted_at\":\"\",\"area_id\":\"\",\"source_id\":\"\",\"source_type\":\"\",\"uploaded_at\":\"\",\"checklist_items\":[{\"is_section\":false,\"location_detail\":null,\"company_id\":null,\"response\":\"True\",\"spec_ref\":\"\",\"updated_at\":\"\",\"response_type_id\":\"24e6efab-0f52-446f-9cc5-db49caaa1ce3\",\"more_info\":\"\",\"area_id\":null,\"checklist_id\":\"{THE_SAME_RANDOM_GUID_ABOVE}\",\"comment\":null,\"touched\":true,\"position\":1,\"uploaded_at\":null,\"template_item_id\":\"990d1376-4892-45a3-ae14-bd0c8bdffa67\"}]}]"
Note.
  • You have to generate a unique GUID (i.e. RANDOM_GUID) for each uploading checklist record
  • The checklists attribute is a quoted JSON as shown above.
Hope it helps.
Cheers,
Eason Kang
Developer Advocate
