How do I deserialize DynamicJsonResponse content into objects with .NET Autodesk.Forge API calls?
I would like to build some tools that let me browse our BIM 360 hubs, projects, folders, and items. Right now I'm just trying to prototype and see what's possible. I've successfully called against Forge with HTTP GET and POST using Postman and tokens I've generated.
When I build API clients I typically create classes representing the business objects that the API returns, and then use a json deserializer to populate a collection of them on GET. When I want to POST I serialize objects back to json.
I'm reviewing various samples on Autodesk-Forge's GitHub and it initially seemed as though the best path forward for a .NET application was to use NuGet Autodesk.Forge which provided various API-calling objects (HubsApi, ProjectsApi, FoldersApi, etc.). The NuGet also provides objects... Hub, Project, etc. Cool. Maybe I can get these, throw them into ViewModels, and do something with them?
I can setup a two-legged token and can use GET, but the response comes back as DynamicJsonResponse. Okay. So far I've found...
- The API object returns DynamicJsonResponse.
- The DynamicJsonResponse has a Dictionary, and I care about the entry with the key "data"
- This is a DynamicDictionary
- It has an element within itself that eventually describes the attributes of the Hub.
- Nothing so far indicates that I can just get a "Hub" object
Scope[] scopes = new Scope[] { Scope.DataRead, Scope.DataWrite, Scope.BucketCreate, Scope.BucketRead };
oauth2TwoLegged = new TwoLeggedApi();
twoLeggedCredentials = oauth2TwoLegged.Authenticate(FORGE_CLIENT_ID, FORGE_CLIENT_SECRET, oAuthConstants.CLIENT_CREDENTIALS, scopes);
HubsApi hubsApi = new HubsApi();
hubsApi.Configuration.AccessToken = twoLeggedCredentials.access_token;
dynamic response = hubsApi.GetHubs();
DynamicDictionary innerDictionary = (DynamicDictionary)((DynamicJsonResponse)response).Dictionary["data"];
This appears to be the case with each of the API objects. I've gone through a few of the .NET sample projects (one is WPF, one is Windows Forms, one is ASP.NET MVC) and they all seem to make Forge calls a little differently.
I feel like I'm missing something. Shouldn't I be able to deserialize the resulting json from HubsApi into a Hub? Or from ProjectsApi into a Project? Is there an easy way to do this? Also - all the same questions to serialize data and push it back to BIM 360.
