Forge - APP Authentication - Obtaining 2-Legged Token
tkeyser5
tkeyser5
What is the trick to obtaining the 2-legged token?  I have tried, to no avail, by following these instructions:
https://forge.autodesk.com/en/docs/oauth/v2/tutorials/get-2-legged-token/
It shows you have to replace the Client ID and the Secret but does not say what editing tool is required or how this is actually done. I have tried using Node.js and Ruby. I get syntax errors.
This should not be this difficult. So if anyone can shed some light I would be eternally grateful.
Thanks.
rosalesduquej
Please note that normally the best way to obtain support for Autodesk Forge APIs is through the Forge API help. Please visit https://developer.autodesk.com/en/support/get-help for information.
The Forge API's are REST based API's so using any tool to point to an endpoint of the API will return a JSON response including the information requested. In your case a 2 legged authentication token.
Something like POSTMAN or Insomnia REST could be 2 applications to handle different API calls, it is quite a nice set of tools to retrieve this responses.
On the code side, we have different SDK's that address the Forge Platform API's, we have a NPM for Node called forge-apis and a Nuget for .NET development and also a Java Maven which includes already the functions to use the platform.
Check this tutorial workflow here - http://learnforge.autodesk.io/#/
Also you could simply use this from your Terminal/ Command Prompt, I wrote a blog post a while ago to do a simple workflow to use the Forge API's. Check it out here: https://forge.autodesk.com/blog/tutorial-using-curl-2-legged-authentication-model-translation
Let us know if you need any further help.
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
tkeyser5
Acceptable. Thanks.
