Dear community,
This is a note about recent update -
as a part of pre-work for future, Field API's route methods (i.e., POST, GET, PUT, etc.) used in the API calls are made strict.
If you are using the correct verb (i.e., the verb indicated in the documentation), you will not see any difference. But if you are not using correct ones, you will get an error.
Just in case FYI.
Solved by mikako_harada. Go to Solution.
ps. Update went out today (11/30/2016)
(accepting as solution to keep the system quiet 😉
