Bim360 API to read user created attributes of polygon in dwg
A Polygon in AutoCAD Drawing has the following attributes: Polygon Number, Polygon Name
In BIM360, On click of properties Icon, it shows only Polygon ID, Layer Name, Geometry but not user created / entered attributes such as Polygon Number, Polygon Name as illustrated in attached file.
Please let me know reference in BIM360 API or sample code to search user created attributes such as Polygon Number and Select the Polygon.
Sreedhar
Regency InfoTech
mikako_harada
Hi Sreedharl,
I don't get to have enough experience using dwg nowaadays. But sounds like Forge Model Derivative API or Viewer might be the one you want to use:
https://developer.autodesk.com/en/docs/model-derivative/v2/overview/
Could you try posting to stackoverflow?
https://fieldofviewblog.wordpress.com/2016/10/27/where-to-get-help-about-forge/
There are more people from Forge team monitoring stackoverflow.
Also, you may want to look at this post to understand the big picture of relationship between BIM 360 and Forge:
https://fieldofviewblog.wordpress.com/2017/01/17/bim-360-and-forge-overview/
Mikako Harada
Developer Technical Services
