I am using the BIM360 Field API to pull all equipment info using the "/api/get_equipment" call. The issue is that I am not getting any data in the feed for custom values. The key:value pair is there, but the value is always '[ ]' (i.e. null).
Solved by mikako_harada. Go to Solution.
Hi jsquaredz,
Could you try details=all? I did some digging sometime back and wrote about it:
https://fieldofviewblog.wordpress.com/2015/08/25/apiget_equipment-details-parameter-explained/
I hope this helps.
I agree. Here it is:
CS-30448
API documentation - please add get_equipement details=all
(I think I picked up from the internal conversation among my colleagues. I must have assumed somebody else is taking care of updating it at that time...)
