Automate model publishing process in BIM360 with Forge API
volodymyr.dobrzhanskyi4DNLP
Hi everyone,
I've been trying to automate model publishing process in BIM360 with Forge API.
Sometimes, publishing won’t start.
For example, I send the publish command, and receive it’s id and status : committed.
After that, I a create webhook, with event: dm.version.modified.
Publishing doesn’t start.
On the next day, I send publish command for that model, and I receive its id and status:committed again, and I have an error in creating webhook, because it is already created.
Model begins to  publish.
So the problem is  that the publish command doesn’t start publishing from the first time.
I’ve posted a question on Stackoverflow website SOlink
but still don’t have an answer for my issue. I’ve provided there some operation id’s.
Does anyone know how to deal with it?
BIMologist_
Were you able to resolve your issue and also if you can share what you have done to automate the publishing?
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
