BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
ACC Docs error: Permission "['PUBLISH', 'VIEW', 'DOWNLOAD', 'COLLABORATE']" throws 400 error with POST projects/:project_id/folders/:folder_id/permissions:batch-create endpoint
1 REPLY 1
JvBMov
383 Views, 1 Reply
When I apply the "View/Download+Upload" actions for a user:
at the endpoint https://forge.autodesk.com/en/docs/acc/v1/reference/http/document-management-projects-project_id-fol...
I get a 400 error:
 Error creating permissions 400, {"code":"ERR_BAD_INPUT","title":"The request has invalid header or body","detail":"Given actions PUBLISH,VIEW,DOWNLOAD,COLLABORATE is invalid"}
All other documented actions are working fine. Shuffeling the actions (for instance to : ['VIEW', 'DOWNLOAD', 'COLLABORATE', 'PUBLISH']) does not fix the problem. Is this a known bug? This applies to both template and regular projects.
1 REPLY 1
mikako_harada
in reply to: JvBMov
There is a difference in acceptable parameter for Autodesk Docs.  There is a separate documentation:
https://forge.autodesk.com/en/docs/acc/v1/overview/bim-360-compatibility/docs-compatibility/
equivalent one is:
PUBLISH,VIEW,DOWNLOAD,COLLABORATE,PUBLISH_MARKUP
The documentation needs to be update. We will report to the documentation team and request to include add both parameter in one page with a clear tag BIM 360 vs. ACC. (so that we don't need to do "diff" every page.)
Sorry about confusion.
Mikako Harada
Developer Technical Services
