BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
ACC Administrator tutorial - include Project members Access Level(s)
1 REPLY 1
kevin.bza
204 Views, 1 Reply
Greetings,
https://tutorials.autodesk.io/tutorials/acc-admin/
This tutorial helped a lot. Thank You!
When displaying the Project User table, is a code edit available to include the Access Level(s) of the Project Users.
Access levels being: Project Member, Project Administrator or Executive.
Thanks for your patience,
K.
Tags (1)
1 REPLY 1
kevin.bza
in reply to: kevin.bza
I am busy with this, found a temporary solution ...
... Edit the Hub Browser tutorial sample
... ... adjust the scope set in the APC.CS class
... ... in the PREPARETOKENS method of the AUTHCONTROLLER.CS class, add a break at the result of the method to provide a chance to capture the token values
Run the solution, copy a token value to the clipboard
Add the token value to a CURL call like
curl -v 'https://developer.api.autodesk.com/construction/admin/v1/projects/valid-project-id/users' -H 'Authorization: Bearer token-value'
Execute the CURL in Terminal and ... Viola! ... the JSON has all the user data, including the access level per user.
Technology Administrators
