What is the equivalent of print?
bugsdabunny
bugsdabunny
What is the equivalent of print in bifrost? I just want to see the values in an array I've created, but adding a watchpoint does give me anything, its all blank. Is there a simple way to print an array?
Christoph_Schaedl
The graph needs to be connected to an ouput to get watchpoints working.
https://forums.autodesk.com/t5/bifrost-forum/visualize-data-in-detail/td-p/8986093
https://youtu.be/ISaGk_V6dAg
https://linktr.ee/cg_oglu
bugsdabunny
That is a cool tool and I will check it out. I don't understand what I've done wrong here, seems like I can't print simple things... I'm very new to Bifrost, any help is appreciated. I've attached a screenshot of my graph
ihooper
You need for Maya to pull on the data. Try feeding those values into an object that gets drawn in the viewport.watchpoint.png
Ian Hooper
UX Architect
bugsdabunny
Ok that works, thank you!
