Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Vray Bifrost error
1 REPLY 1
gtmd8s18
372 Views, 1 Reply
Vray Bifrost error
Checking with latest Autodesk Maya with Vray. Both latest versions installed,  but when I run the application with vray plugin enabled, it gives the following error:
Error: VRay: Could not load the Bifrost module! You will not be able to render Bifrost as isosurface or metaball. The error message is:[loadLibEx] 126: LoadLibrary failed (126): The specified module could not be found.
Maya Version 2023.2
Vray Version v6.00.02
Appreciate any advice. Thanks.
1 REPLY 1
Are you trying to render a Bifrost Graph or the old liquids?
https://linktr.ee/cg_oglu
