Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
VolumeScope Flowline Rendering
1 REPLY 1
yourshawm
303 Views, 1 Reply
Hi All,
I have a cached vdb (via 'write_OpenVDB') I'm reading in, and using the volume scope to get the flowlines; all seems to look ok in viewport but I can't seem to get it in renders. Tried what I could find on the forums but not sure what I'm missing, graph attached below:
-Image 1 shows my graph reading in the vdb cache
-Image 2 shows an arnold render with the setups I could find on the forums (even with aiStandardSurface baseColor set to default grey it doesnt show up)
-Image 3 shows a watchpoint of the scope out, if that's handy
Thanks!!
M
Image 1Image 1Image 2Image 2Image 3Image 3
1 REPLY 1
Aslan.Jafari
in reply to: yourshawm
Thank you for reporting the issue.
You could use "set_Arnold_strands_settings" node in between your volume scope and the output node. You should be able to render your strands with Basis Override set to Linear.
Currently we have a regression in 2.3.0.0 that prevents us from rendering flowlines from volume_scope as default, Catmull-Rom and B-spline.
This issue is logged as ARNOLD-11505
Aslan Jafari
Sr QA Analyst
