Is there a way to see the results of a node? Say I have an Add node with 2 value nodes plugged into it, one with a value of 1 and another with a value of 2. I would like to see the output value of the add node so I know it is calculating as expected. So in this case I should see 3. I would also like to see the incoming values as well. Is there any way to see the value instead of simply the link to the node and its attribute? incoming
