Using Bifrost – perspective on the current UX
Many people who are accustomed to the Maya node editor look at Bifrost and comment on how fresh and modern it appears. It is our hope that this impression is not just skin deep. The user experience (UX) of a feature like Bifrost depends upon many factors, including performance, information architecture, learning resources, interaction patterns and so much more. Just as we plan to introduce more and more capabilities in future releases, we also intend to improve the usability and experience of working with Bifrost.
Some of the UX improvements that we have planned are major development efforts, while others are technically trivial, but require a lot of user testing and iteration to get it “just right”. To give you an idea of the breadth of things we are working on, here is a high-level list of issues that we know are negatively affecting our UX:
Backdrops |
Adjust the font size, background color and even collapse your backdrops. |
Browsable Node library (in-app) |
Find what you need more easily. Browse all installed compounds, read summary descriptions, search and filter the list. |
Browser Improvements |
Connect the searchable library of graphs to the online community. Improve searching/filtering. Remove legacy Bifrost content from the old content browser. |
Clear in-line messaging (InfoBar HUD) |
Make the information bar at the bottom the graph easier to understand (and easier on the eyes). |
Contribute to and learn from a social community |
Integration with Screencast and other tools to make it easier for you to share your tips and tricks with the community. |
Customizable hotkeys |
Everyone works a little differently and having the right hotkeys for how you work can make a big difference. |
Examples and Tutorials |
We will continue to create more sample graphs and learning materials. |
Fast & Responsive UI |
We will continue to work at improving the speed at which you can work with Bifrost. |
Get and Set Property Improvements |
Automatically populate a drop-down list with available properties, including type information. |
Get Started Learning Path |
Quick, in-product steps to get started for those who are completely new to visual programming or anyone who wants a shortcut to familiarize themselves with Bifrost. |
Graph filters and search |
Find and highlight a particular node, or type of node with some default filters and keyword search. |
Graphs (tools/presets) |
Sample graphs with some additional guidance that can prompt for required inputs and settings. |
High-level compounds |
We will continue to build more high-level compounds that will allow for very easy to understand and build graphs. |
Icon/color identifiers |
More state indicators (i.e. disabled nodes appear disabled); More node icons. |
In-app node descriptions |
Improved Info panel content |
In-node Parameter editing |
Edit some attributes directly on the node. |
Mini-map |
Navigate the scene and understand your context via a miniature birds-eye view of the graph. |
Mouse-over contextual help (tooltips) |
Short, just-in-time information about tools and UI elements. Possibly extended to a “learning mode” where port and parameter info is available at your cursor. |
Navigation bookmarks |
Save and return to specific locations (both across and inside) anywhere in the graph |
Output to final frame with no extra steps (terminals and materials) |
Improvements to the rendering workflow. |
Parameter Editor Widgets |
Customize how the Parameter Editor displays the attributes for your compound. Choose from different standard widgets (i.e. radio buttons, dropdown pickers, etc.), set min/max ranges and default values. |
Port grouping |
Add port groups to more compounds. Make it easier to make and edit groups. |
Portals / deep connections |
Connect data from nodes deep in a graph with nodes at a much higher level without having the “thread the wire” through each level. |
Publish to/download from a community repository of nodes/graphs |
Find content on the community compound library or publish and upload directly from in-app. |
Publishing Improvements |
Metadata (tags) and other improvements to the publishing workflow |
Sticky notes |
Add longer format text notes to the graph. Include color coding, font and color control. |
Tab search filtering |
Add the ability to set which nodes are displayed based on metadata tags (i.e. hide “expert” nodes) |
Type wrangling on nodes |
Streamline (or eliminate as much as possible) the process of setting value types. |
Viewport improvements |
Improve the ability to display things in the viewport (i.e. forces, influences etc.) |
Watchpoints / diagnostic view |
Make watchpoints easier to use, less cumbersome and easier to understand. Introduce new diagnostic visualizations that will help with graph debugging. |
Wire management |
Add “elbows” and “cable bundles” to allow for simplified graph appearance. |
This is a long list and it is not even a complete accounting of all the improvements we want to make. Looking even further out we hope to embrace entirely new ways of working that will be more creative and inspirational. This is just the start!
Ian Hooper
UX Architect
