Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
TrisArticulate
3 REPLIES 3
darioOrtisi
382 Views, 3 Replies
TrisArticulate
Hi.
I will like to share with all this simple (something, who know) mograph animation scene.
The idea is based to this: https://youtu.be/oKBVjWoS5_U?t=750
And off course is not finish yet. I will like to know how to offsetting the vertices and also, maybe extrude there is a compound somewere here in the forum.
Enjoy
3 REPLIES 3
andrew.bkly
in reply to: darioOrtisi
Hey there,
Yeah there is an extrude compound on the Area downloads.
https://area.autodesk.com/downloads/all/compounds/
It looks like its able to offset the faces inwards for you as well as a function. I was able to build what you are going for quite quick with it.
Manually you could lerp between your faces points and the average center points to offset them inwards. There was a master class which explains how to break up the mesh into faces and manipulate each face which I found helpful but quite complicated, you may know already from making your blue points. Link below and some screenshots.
https://youtu.be/rUY9pO7UCjs?t=597
darioOrtisi
Hi @andrew.bkly
Thanks. Yes i followed this Marcus Masterclass to get the disjoint face. As you says is complicated. This is why i share with all something ready. Even to me is complicated this masterclass(more complicated)
thanks
darioOrtisi
And here the updated scene with extrude
