Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Transform of instances
1 REPLY 1
385 Views, 1 Reply
Hello. I have a trouble with bifrost instances in Maya.
I created following simple graph which places 100 instances of the red cube on the surface of the  sphere.
It works fine.
But the transform node in Maya is moved or rotated, the instance alignment is disrupted as shown in the following picture.
Such disruption only occurs on viewport. The rendering result with moved transform node is what I expected as following.
In the viewport, the transformation of the bifrost graph seems to be applied after transformation of each instance.
Once I convert instances into geometry using bake_instanced_geometry node, the display in the viewport and the rendered result will match.
Is this a bug? or I make some mistake?
I use Bifrost 2.2.0.1, mtoa 4.1.1.1 and Maya2019.2.
Thanks.
Labels (1)
1 REPLY 1
mjcg91
This is a known issue and is already logged.
BIFROST-3391 Viewport: Instances explode when you transform them in Maya
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
