Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Stupid question 18/49675 in an infrequent series
3 REPLIES 3
valhallen
332 Views, 3 Replies
Compare arrays?
I have an array of point positions from a strand, then an array of point positions from a resampled strand .. I want to get the new points that are not in the old points array, so I can offset them and make another strand ... all in the hopes of avoiding an MPM setup that i can't get to work ๐Ÿ˜„
Trying to avoid an iterate that goes through both arrays, as they could get rather large ...
I have tried intersect arrays ... both with the original nested arrays and flattened versions ...
Labels (1)
3 REPLIES 3
valhallen
in reply to: valhallen
Note:  this doesn't need MPM anyways - swatting a gnat with a nuke
mjcg91
intersect_array does not yet work with float3, which is why you get this error.
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
valhallen
in reply to: mjcg91
Sadness.  Thanks for confirming though.  Found another way using the indices and a modulo ๐Ÿ˜„
