Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Strange bifrost graph caching
2 REPLIES 2
vamp.tobias
785 Views, 2 Replies
i am having quite a wierd issue with the file_Cache node . i try simulating the standard explosion example and then caching it .
While the example works in the write mode showing fire and so forth
as soon as i change the file cache node to the read mode it only shows the smoke.
Can someone help me solve this problem?
2 REPLIES 2
vamp.tobias
in reply to: vamp.tobias
Problem is solved . the file cache node was after the assign material node and not before it causing it to read the material wrong .
Firestorm185
This, literally saved my bacon. Doing a fire assignment in Maya right now, and coming from Blender I had no idea what I was doing, the cache node was in the wrong place, like yours, and I couldn't see ANY fire at all. Swapping the cache node to behind the material node totally fixed my problem! You're a lifesaver!
