Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Strands color from texture
4 REPLIES 4
rstefan
260 Views, 4 Replies
I'm trying to find a way to color the strands using the texture found on the geometry they are created on.
From what I have read and if I understood correctly, it is a two-stage process.
First, I generate the points that "extract" the color, and second, I transfer the color property from the point
to the strand generated by the point. The first part is ready, I have the colored points according to the texture but
I don't know how to transfer the color property from each point to the corresponding strand. To be clear: if I have a white point I want a white strand, if I have a red point I want a red strand.
If anyone has time, I have attached a clean scene. Thank you!
4 REPLIES 4
sepu6
in reply to: rstefan
Hey, if you look carefully at your properties, you'll see that the point_uv does not get transferred when you use create strands along the normals and there is not promotion anyway.  So create a point_uv from the sample node but the component should be strands instead of pts.
rstefan
in reply to: sepu6
Wonderful, thanks again sepu6! Another problem: after I add an MJ extrude strands compound, it seems that it does not transfer that property further, even if it is entered in the transfer properties tab.
Any idea?
sepu6
right because it accepts point properties, however, if you are using the set strand profile and rendering with Arnold you do not need to convert to a mesh. It will be a lot faster they way that you are doing it anyways instead of a mesh.
rstefan
in reply to: sepu6
Yeah, I think I'm sticking with Arnold for now. Thanks!
