Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
source_air node doesn't respect changing values
4 REPLIES 4
calibrix
472 Views, 4 Replies
I think this might be a bug, but I'm not entirely sure. I've created a setup where I've set a point attribute called "point_fog_density_emission_rate". This is the same geo property that is used by the vary_source_propery. I'm setting the value using a fractal noise node that is hooked up to time. However, the aero emission doesn't appear to change over time. I've double checked that my source values are changing by coloring vertices and playing back the viewport. Can someone please shed light on why this is happening? It appears I can't upload a maya file, so I've made a screen grab of the relevant part of my graph.
Tags (3)
Labels (1)
4 REPLIES 4
michael_nielsen
in reply to: calibrix
Please zip your maya file then it is possible to attach it. Then we can have a look at your scene.
Cheers,
Michael
Michael Nielsen
Principal Engineer
calibrix
in reply to: michael_nielsen
Ah, thanks. Here is my scene file. Please take a look.
michael_nielsen
Thanks.
I inserted a dump_object node after a vary_source_property node and after your custom graph and looked at how they differed. It appears that in order for the solver to re-voxelize the input object when the geometry is static but only properties change, a property called "has_animated_properties" must be set on the object, see image below. I have also attached the updated scene file. It appears to work now.
Cheers,
Michael
Michael Nielsen
Principal Engineer
calibrix
Ah I see. Thanks for helping me understand how this works.
