Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Snow simulation is slow
8 REPLIES 8
Message 1 of 9
summerJYEW4
852 Views, 8 Replies
Hi!
Simulation is slow when the input face scale is in meters.
I adjusted by changing Detail Size of points_to_level_set and Multiplier of vary_source_property.
Is there any other way to speed up the process?
I attached my compound.
The input is a face, which is used as an emitter to simulate snow.
For example, The input is the roof of a house then create a snow mesh on it.
Physically, it is correct to make the roof a collider and let the snow fall from other emitters,
I'm doing this to speed up my work.
Thanks for your advice!
I want to expect simulation is quick like this picture in centimetersI want to expect simulation is quick like this picture in centimeters
8 REPLIES 8
Message 2 of 9
wuhailu
in reply to: summerJYEW4
I heard that MPM will have GPU version in the future, which can improve the simulation speed.
Message 3 of 9
summerJYEW4
in reply to: wuhailu
I'm glad to your reply!
Really? Is that information anywhere?
Message 4 of 9
Its slow yes. It does get faster if you use faster hardware.
There isnt much to say. High quality simulation does take time.
https://linktr.ee/cg_oglu
Message 5 of 9
wuhailu
MPM was developed by the Jixie Effect team (http://www.jixiefx.com/) MPM algorithm has mentioned GPU http://www.cgchannel.com/2018/11/videos-see-siggraph-asia-2018s-best-technical-papers/
Message 6 of 9
Christoph_Schaedl
Yes but Bifrost is CPU only. For now.
And if somethign gets rendered on GPU doesnt mean its faster.
There are a lot of things out there that are slower on GPU.
A typical fx workstation does have 256GB of ram.
I dont see cheap GPUs in the near future with that amount of ram.
Message 7 of 9
summerJYEW4
Thank you for linking.
I was able to see that GPU was mentioned.
In hardware, there is nothing that can be done by users, so it seems that we will have to wait for a response.
Message 8 of 9
Thanks for your reply!  I understand what you say.
I want to make it faster. In result, quality is reduced. OK
Do you have any ideas?
Message 9 of 9
summerJYEW4
OK, this topic is closed.
Thanks guys!
I will continue to use this forum.
See you on the next topic!
