- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Want to automate the run a set of MPM sim based on a pre-defined set of values for some of his source_mpm properties.
I suppose is possibile in some way to define a matrix with in the vectors the different values for every run, but wondering if there is any better way to achieve this (i.e. the "set_particles" or "set_property_any_node").
Also since every run does have different parameters didn't find a way to simply print these parameters value in a legend in the render.
